xCubedox
Connect wall oven in smart home
JUMP TO SOLUTION
good morning I'm trying to connect the oven to the smart home application connect it to the wifi network but it does not detect the application tells me that I must use the easy connect but when I place it I can not detect it yet if someone had this problem
1 SOLUTION
Re: Connect wall oven in smart home
JUMP TO SOLUTION
Please contact the Samsung SmartThings team directly at 866-813-2404 for further assistance with this connection issue.
9 REPLIES 9
JUMP TO SOLUTION
Please provide the full model code of the oven so that we can best assist.
xCubedox
JUMP TO SOLUTION
the model is NV51K7770SS
JUMP TO SOLUTION
Have you tried re-installing the app? Are you connected to the 2.4 GHz Wi-Fi band?
xCubedox
JUMP TO SOLUTION
i try to connect to 2.4 and 5 ghz band and the app dont find the oven, search in the web i look in the settings the easy conect and the oven generate a wifi connection but doesnt work to connect to the app
JUMP TO SOLUTION
What kind of device are you using to set this up? Have you tried turning off mobile data while setting this up?
xCubedox
JUMP TO SOLUTION
i try with wifi but not any lucky
Comet
JUMP TO SOLUTION
Go with the 2.4
You wont have any luck with the 5 with appliances. Do you see a "enter model code" option in your app? Connect your phone to the 2.4, do the wifi thing on the stove like you were doing, and then put in the model code. If the oven is close enough to the router to see it, it should connect then and you can set up its automations and app control.
---My Signature---
If you're anticipating a follow up to one of my posts, please like my post or tag me. I don't generally go back to posts I have replied to unless I get pointed there.
xCubedox
JUMP TO SOLUTION
is supposed to connect in easy connect in this section the oven creates a wifi network to which you connect with the password 1111122222 then you log in smart home and it is detected but is not performing the work as is
JUMP TO SOLUTION
