ElliD
- Mute
01-07-2023 12:11 PM in
Smart Home Support
Hello I connected my neighbors appliances on accident to my smartthings account. I have been trying to remove it but there is no option to delete or edit. Please help. Thank you.
Solved! Go to Solution.
- Tags:
- smartthings
Dante1
- Mute
01-07-2023 07:36 PM in
Smart Home Support
Tap and hold the appliance. Then select edit. To forget it simply click unpair and it will remove it from your device.
Dante1
- Mute
Smart Home Support
ElliD
- Mute
01-07-2023 07:42 PM in
Smart Home Support
Thank you for your response. It's still didn't work.. what I am doing wrong 🙃
ElliD
- Mute
01-07-2023 07:44 PM in
Smart Home Support
Wait!!! I tried again and it worked!!! I feel stupid. Thank you again!!
Dante1
- Mute
01-07-2023 07:45 PM in
Smart Home Support
Glad I could help
ElliD
- Mute
01-07-2023 07:46 PM in
Smart Home Support
Finger placement made the difference!!
