atehrani
Samsung Connect Home Pro solid magenta
JUMP TO SOLUTION
The wifi appears to be stuck with a magenta light. What should I do? Wait it out? Or is it bricked?
1 SOLUTION
Comet
Re: Samsung Connect Home Pro solid magenta
JUMP TO SOLUTION
Unplug the hub, hold in the reset button while plugging it back in and wait for it to stop flashing. If it does it again immediately, I vote hardware.
---My Signature---
If you're anticipating a follow up to one of my posts, please like my post or tag me. I don't generally go back to posts I have replied to unless I get pointed there.
3 REPLIES 3
JUMP TO SOLUTION
For the best assistance with your Samsung Connect Home Pro, please call 866-813-2404.
Comet
JUMP TO SOLUTION
---My Signature---
atehrani
JUMP TO SOLUTION
A reset worked, thanks for the help!
