Art_Ramon
POWERbot R9350 Disable/Enable Charging for cleaning resumption
JUMP TO SOLUTION
I want to turn off the Charging For Cleaning Resumption option. How is this done?
1 SOLUTION
Re: POWERbot R9350 Disable/Enable Charging for cleaning resumption
JUMP TO SOLUTION
We certainly can, we will tag it on the forum so that it will appear with other feedback, ideas, and requests. This will allow your post to be more easily found in the event that Samsung product groups are seeking outside feedback/requests/ideas regarding our products. Smiley Happy
10 REPLIES 10
JUMP TO SOLUTION
I'm not familiar with the option you are referring to. Can you provide further details of your concern or provide an image of your question?
Art_Ramon
JUMP TO SOLUTION
Art_Ramon
JUMP TO SOLUTION
Recharge and Resume
JUMP TO SOLUTION
Thanks for clarifying that for me. The Recharge and Resume feature is an automatic method to have the device to clean. I believe the Repeat Clean is the only cleaning method that operates uses the Recharge & Resume feature. Using the Spot Cleaning will disable the Recharge & Resume feature to happen. Changing the Cleaning method would be the only way to do this.
Art_Ramon
JUMP TO SOLUTION
There is no repeat clean option on the R9350. On the POWERbot itself, there is only Spot and Auto methods, and recharge. In the app, there is only Auto, Recharge, Select and Go. I see no other options to disable this feature.
JUMP TO SOLUTION
It looks like the Repeat mode is only available to be turned on by using the Smart Things app. What cleaning method have you been using? have you been using Auto or Spot cleaning?
Art_Ramon
JUMP TO SOLUTION
I've only used Auto mode, and I kick it off via Smartthings schedule. I've also have scheduled it via it's own interface, same result.
JUMP TO SOLUTION
I wanted to double check before I provided confirmation on your inquiry. It looks like this model doesn't have an option to disable the Recharge & Resume feature. There are some models that offer a cleaning method, that allows the PowerBot to clean once and return back to the charger station. It looks like this model would continue cleaning until the floor is completed. It is possible to use the manual cleaning to clean certain areas, it out it using the Recharge & Resume, but you would have to direct the device to the area.
Art_Ramon
JUMP TO SOLUTION
The only manual method is to control the direction of the POWERbot via the remote or app. The clean button on the POWERbot only does Auto. All means of activating a clean via the app are all Auto, schedules via its own scheduler or a Smartthing automation are also all Auto. I've tried all manners of work arounds to try and disable the Recharge and Resume, but have not found any. Can this disable feature be suggested to the developers?
