usertDy6DOFSTZ
Powerbot 9250 grinding noise
JUMP TO SOLUTION
My Powerbot 9250 makes a horrible grinding/rattling noise when it runs. I’ve tried the “Request  Service” link but it keeps just saying that my bot is registered and to look it up in My Products but it’s not listed there. How can I get my powerbot fixed??
1 SOLUTION
Re: Powerbot 9250 grinding noise
JUMP TO SOLUTION
We are sorry to hear about this. Please send the model and serial numbers to this PM Link.
3 REPLIES 3
JUMP TO SOLUTION
We are sorry to hear about this. Please check the steps in this Troubleshooting Link to see if this helps.
usertDy6DOFSTZ
JUMP TO SOLUTION
No, that does not work. I’ve disassembled, inspected, and cleaned it multiple times with no difference. It makes the noise no matter the surface.
JUMP TO SOLUTION
