AI Optimization Request for Network, Battery, and System Performance
(Topic created: 07-15-2025 05:22 PM)
Skull2028
Cosmic Ray
Suggestions
Dear Samsung Development and Developer Team, Please improve AI network speed optimization, as my device often shows 1โ€“2 bars. Add AI auto-fix for signal issues, overheating, and location-based problems to ensure better stability. I use 60Hz to save battery and reduce heat. I prefer it over 120Hz but still want better speed and performance for both, especially for gaming and productivity apps. Please improve 60Hz quality and reduce heat. Add AI control for brightness and background activity, which causes overheating. This must be auto-fixed by AI. Also include AI-powered Find My Device features for missing Galaxy Watch, Buds, and accessories, with more smart detection tools and advanced AI functions. I hope the full system is improved with modern AI-driven design for long battery life, secure data, and stable fast speed. I truly hope your team supports my suggestion for future Samsung features. Thank you
Suggestions
That's like 2 major updates from now but I know that they can fix over heating and signal strength.Theres already loss prevention features already implemented and there is smart tracking features like Ultra wide band.I do think an AI battery feature would be nice, something like routines but with voice commands.
USBetaModerator3
Beta Moderator
Suggestions
Hello,
Thank you for taking the time to share your feedback with us.
We truly appreciate your suggestions and will share them with the relevant team for review and consideration in future updates. Your input helps us improve the overall One UI experience.
Thank you again for supporting the One UI Beta Program!
Regards,
One UI Beta Team
