Showing results forĀ
Search instead forĀ
Did you mean:Ā
Add Protect Battery Setting
(Topic created: 06-07-2022 05:15 PM)
Nick515
Cosmic Ray
Suggestions
Can you add a protect battery setting to limit charging to 85% like on the S22?  Thanks.
USBetaModerator2
Beta Moderator
Suggestions
Hello,
Thank you very much for your suggestion. Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept. We appreciate your contribution to the beta program.
Regards,
One UI Beta Team
USBetaModerator2
Beta Moderator
Suggestions
Hello,
Regards,
One UI Beta Team
GalaxyUser00
Cosmic Ray
Suggestions
+1
