Additional Setting Toggles on Power Saving Mode
(Topic created: 11-24-2023 03:11 AM)
izephyr
Nebula
Suggestions
In the Power Saving settings, there are a few options as toggle to turn on/off, for example, Decrease Brightness by 10% or Turn off AOD.
There are few other things mentioned as power saving feature but doesn't have a control. Like
1. Background Network Usage
 (Can also be separated by Wi-Fi/Mobile Data)
2. Syncing
3. Location Checking
4. Motion Smoothness etc.
It would be great if these things also had a control based on user requirements.
Be sure to click " ✓ Accept as Solution" when you find an answer that works for you and drop some
Chef31684
Red Giant
Suggestions
Seems like adding so many toggles in one place would cause clutter. All those things you can turn off in the quick panel or in their perspective allocated settings
USBetaModerator2
Beta Moderator
Suggestions
Hello,
Thank you very much for your suggestion.
Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept.
We appreciate your contribution to the beta program.
Regards,
One UI Beta Team
