Showing results forĀ
Search instead forĀ
Did you mean:Ā
Battery icon is too small.
(Topic created: 12-17-2024 04:46 PM)
Dej00
Suggestions
In this 2nd version of the beta, the battery icon in the status bar is just to small. I love the pill design though, it's very clean. I'd say it needs to be longer and the number bigger. Especially when it's on the Always On Display, it's to hard to read.
Indy11Forever
Suggestions
I wish I could turn it off. I don't need it or the connection info. I want to put the clock on the right side.
youu
Black Hole
Suggestions
Yes I agree it's small
DiegoKaku
Galaxy
Suggestions
Oh guys, you need glasses, not bigger UI.
I easily see the battery number more than 3ft away
userHmB3nEfQJZ
Suggestions
And you need to get a clue.
JimChagares
Suggestions
Way too small and unreadable. Bring back the UI 6 percent as a choice.
userHmB3nEfQJZ
Suggestions
Just received my S25 Ultra, upgraded from an S22.  The battery icon is ridiculously small and poorly designed.  Their UI team needs to be fired.  It's impossible to read once it's below 70% if you don't have super vision.
Members_JOfZnmc
Suggestions
Agreed. Switched from a pixel 9 pro and was surprised to find the wifi icon and battery icon so tiny
