Better Media Output, Device Control, and Smart View menu integration
(Topic created: 09-25-2023 03:23 PM)
Casosix
Halo
Suggestions
All three of these menus, accessable from buttons on the quick panel, have a clunky implementation. It would be much better if they were actually properly integrated into the quick panel, making them more seamless to use, kind of like how the wifi and Bluetooth menus are on the quick panel.
Also, speaking of the wifi and Bluetooth menus, the animations for opening them from the quick settings? There's no way that's final, that that's going in the public build. Right?
theskeptic
Suggestions
Not to mention the removal of the very helpful Mbps data on the currently connected WiFi. I used that quite frequently previously.
USBetaModerator2
Beta Moderator
Suggestions
Hello,
Thank you very much for your suggestion.
Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept.
We appreciate your contribution to the beta program.
Regards,
One UI Beta Team
