TonyRednil
Cosmic Ray
- Mute
09-03-2023 10:31 AM in
Suggestions
Please make it so dimming lights with smart things only triggers when the lights are previously on or so it starts with the value that the lights are already set to. It is so annoying that when sleep mode ends and I turn it back on my day off my lights will go from whatever dimmer value it was at, even off, to 100% brightness and dim to 0 over 30 minutes.
1 Reply
USBetaModerator 2
Beta Moderator
- Mute
09-04-2023 10:52 AM in
SuggestionsHello,
Thank you very much for your suggestion.
Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept.
We appreciate your contribution to the beta program.
Regards,
One UI Beta Team
![](/skins/images/98108F1B5FF7C597313430288FE14805/responsive_peak/images/icon_anonymous_message.png)
