Showing results forĀ
Search instead forĀ
Did you mean:Ā
Leverage AI to fix motion blur in cameras
(Topic created: 02-20-2025 05:57 AM)
Suggestions
Beta 4 has been a great update so far. Only thing I wish Samsung could try to do is use their AI tech to improve photos with moving subjects and at night. Maybe have a "sports mode" where the camera is using AI to analyze the area and change the shutter speed and iso dynamically.
AlienX
Comet
Suggestions
Motion blur can't be fixed unless Samsung tweak their algorithm with iso and shutter speed balance. When I take picture of my kids from Pixel 7, they are always slightly darker but little to no blur.
The reason they do it is they use higher iso and higher shutter speed and clean up noise digitally. On the contrary, samsung uses lower iso and lower shutter speed to brighten up the image. It results in more light but a blurry mess when moving subjects indoors.
Suggestions
That's what I'm saying. Maybe use AI to figure out a more efficient way to adjust the shutter speed, boost ISO and process the image. The sharpness of a photo should always take precedent over the brightness, like they are with Pixel phones
userlQcCM1wRc8
Supernova
Suggestions
100%
USBetaModerator3
Beta Moderator
Suggestions
Hello,
Thank you for sharing your suggestion with us.
We truly appreciate your input and value your engagement in the One UI Beta community. Feedback like yours helps us better understand the experiences and preferences of our users.
Thank you again for contributing to the One UI journey.
Regards,
One UI Beta Team
