dgruttola93
Cosmic Ray
- Mute
ā12-20-2024 11:30 AM (Last edited ā12-20-2024 11:41 AM ) in
SuggestionsSo while I'm super glad that there was a number put in when the battery gets below 5%, I think that the ! is in the wrong place. The ! should be placed after the battery number, as it is makes more sense in terms of placement. When would you ever put an ! before a number? Seems like an odd choice and I think this should be discussed and changed within the 3rd beta update. Another thing is that the battery can be hard to see when it blends in with a particular app. You can tell in the Amazon app, that the battery number is hard to see against the orange background. I think the battery icon needs a little more revamping
lostone123
Halo
- Mute
ā12-22-2024 07:05 AM in
Suggestions
European??
dgruttola93
Cosmic Ray
- Mute
ā12-28-2024 10:10 AM in
Suggestions
nope. us
ImRyan
Comet
- Mute
ā12-22-2024 08:06 AM in
Suggestions
Or when it blends in and doesn't adjust to the wallpaper. I went to beta feedback and sent a nice message to Samsung about it and said it was display issues and maybe if enough people sent it directly to Samsung through the beta feedback reports they would listen because I don't know how many forums they are actually able to read
![1734883592350.jpg 1734883592350.jpg](https://us.community.samsung.com/t5/image/serverpage/image-id/1215223iA1EA87F206B3948A/image-size/small?v=v2&px=200)
ImRyan
Comet
- Mute
ā12-22-2024 08:07 AM in
Suggestions
That's a dark background vs a light wallpaper. No difference
![](/skins/images/FA668C56CD2CC5427F53EE61D85CE837/responsive_peak/images/icon_anonymous_message.png)
