Dew841
- Mute
Monday in
Suggestions
The power button you can long press it so you can hit the turn off or restart button on your screen. Then you have option too double click for your camera or privacy screen or more. Can we add a triple click? So I can use both my camera and privacy screen with out having to pick one or the other?
Robin621k
Honored Contributor
- Mute
Monday in
Suggestions
Just go buy the Pitaka Button case, you get 3 buttons to map to whatever you want.
USBetaModerator 3
Beta Moderator
- Mute
Tuesday in
SuggestionsHello,
Thank you for taking the time to share your valuable feedback.
We appreciate your suggestions and will forward them to the relevant team for review and consideration in future updates.
Your input is valuable and helps us enhance the overall One UI experience.
Thank you again for supporting the One UI Beta Program.
Regards,
One UI Beta Team
