Showing results forĀ
Search instead forĀ
Did you mean:Ā
Using both wifi and mobile data for downloading streaming feature suggestion
(Topic created: 10-18-2021 02:20 AM)
anonym0us
Star
Suggestions
Can we get a feature suggestion to where we can use both wifi and mobile data for faster speeds for downloading uploading syncing and streaming it used to be a feature on galaxy phones I think it'd be very useful
user751201tmO21
Honored Contributor
Suggestions
Hmmm
So, are you proposing that when something is being downloaded that 1/2 of it is downloaded using WiFi and the other half using mobile data, and then the two halves are stitched together?
Or are you proposing that the phone decides whether WiFi or mobile data is the fastest and chooses the faster?
JawshDarnit
Galaxy
Suggestions
It was called download booster, super helpful. Used both wifi and lte to download large files
user751201tmO21
Honored Contributor
Suggestions
Thanks ... any idea why it's not available now?
USBetaModerator
Beta Moderator
Suggestions
Hello @anonym0us ,
Thank you very much for your suggestion. Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept. We appreciate your contribution to the beta program.
Please note that we used to have a Download booster option which was doing the same but had to be removed due to low usage as well as issues being reported.
Regards,
One UI Beta Team
