What if dark mode and sound mode were separate toggle buttons...
(Topic created: 01-26-2026 08:43 AM)
iluvspring35
Suggestions
Instead of being together with the brightness / volume bar
it would look so much better, simpler and cleaner.
Hx12
Cosmic Ray
Suggestions
Yes this is much better than the buttons being tethered to the sliders. The dark mode doesn't even make sense to be next to the brightness slider instead of a auto brightness button, idk who thought this is a good idea. Just make them separate and let us put the buttons where we want.
USBetaModerator3
Beta Moderator
Suggestions
Hello,
Thank you for taking the time to share your feedback.
We appreciate your suggestions and will forward them to the relevant team for review and consideration in future updates.
Your input is valuable and helps us enhance the overall One UI experience.
Thank you again for supporting the One UI Beta Program.
Regards,
One UI Beta Team
