Showing results forĀ
Search instead forĀ
Did you mean:Ā
Wireless Power Sharing
(Topic created: 10-12-2021 03:03 PM)
Kratos88
Galaxy
Suggestions
This seems like such a small thing but it would be better if "Wireless Power Sharing " can be shortened to "Power Sharing" yo stoo it from scrolling on the quick panel.
USBetaModerator
Beta Moderator
Suggestions
Hello @Kratos88 ,
This would cause a confusion where a device connected via USB charging which cannot be switched to a diff mode but not  turned off vs a wireless power sharing which can be turned off.
Regards
One UI Beta Team
MochaVex
Supernova
Suggestions
Alternatively, @USBetaModerator , the toggle could be put under an umbrella toggle simply named "Power Sharing". Upon opening, wireless power sharing would be shown, as well as USB power sharing. An extra tooltip could be provided saying that the user needs to connect a device to continue with wired sharing.
