ability with Bixby routines to control charging speed
(Topic created: 10-31-2020 03:13 AM)
babyTHANOS
Cosmic Ray
Suggestions
Bixby routines currently doesn't  allow setting a routine based on if battery percentage causing change to super fast, fast, regular charging
1 Reply
USBetaModerator
Beta Moderator
Suggestions
Hello,
Thank you very much for your suggestion. Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept. We appreciate your contribution to the beta program.
Regards
One UI Beta Team
