Showing results forĀ
Search instead forĀ
Did you mean:Ā
system sound
(Topic created: 11-03-2021 05:45 PM)
PrincessMochi
Galaxy
Suggestions
Please add more system sounds we need to be able to add our own sound also.
user751201tmO21
Honored Contributor
Suggestions
You can add your own sound, for Notifications, ringers, and so on ... that capability is in Android 11 UI 3.x
Letta0307
Galaxy
Suggestions
Go to my files and go through all the sounds you downloaded from various apps likes TikTok, fb, ig, Zedge and move or copy them to internal ringtones
USBetaModerator
Beta Moderator
Suggestions
Hello @PrincessMochi ,
As @user751201tmO21 and @Letta0307 mentioned you must be able to add your own sounds as ringtone.
Navigate to settings -> sounds and vibration - ringtone and click on + icon on top right.
Regards
One UI Beta Team
PrincessMochi
Galaxy
Suggestions
I'm not talking about ringtones.
