Keyboard for UN65MU6500F - 65” and Sound Bar?
I bought a Logitech 400 Plus TV keyboard for my UN65MU6500F -- 65.”  We are having a heck of a time getting it to work.  Did we buy the wrong one?  If so, what kind should we buy?  Also, does anyone know what kind of Sound Bar we should buy for this TV?
See more topics labeled with:
Re: Keyboard for UN65MU6500F - 65” and Sound Bar?
That keyboard has unifying receiver to work.  That's only good if you have actual computer hooked up to your TV.  What you need is a Bluetooth based keyboard.   Like this one:  iClever BoostType BK08.  They're known to work with both Tizen and android based TV's.
Thank you.  We did get the Logitech to work finally, but I have not turned it on again to give it another try.  I had my computer on when I was using it, but that should not have had an effect since the USB was plugged into the TV, correct?  I am looking at the iClever BoostType BK08 now.  Thank you for the information.
Like i said If it doesn't work try the bluetooth keyboard.  TX
