Samsung LED Smart TV keeps turning off and on
SOLVED
Re: Samsung LED Smart TV keeps turning off and on
My problem start today.  Bought less than 2 years .  I can't believe a $2000 tv just break down so EASY.   My other cheaper Samsung last so much longer.   I am hoping Samsung can help solve this problem .
Looking for help on this same issue. Model # un43nu6950fxzh
We are sorry to hear about this. Please send the serial number to this PM Link.
SOLVED!!  My Samsung tv has been randomly turning itself on and off for the past few months. I tried every suggestion including changing to a different HDMI port, checking power supply and connections, changing remote batteries, turning off energy saving feature, etc. It’s been extremely frustrating but I was determined to find a solution. And I finally found the fix!!  There is a feature on Samsung TVs called Anynet. This allows you to connect several devices to your tv so that you only need to use a single remote control for all the devices that are connected.  You can access this feature in your tv settings or by a small button labeled Anynet on the Samsung remote. If you are experiencing sudden shut offs, you should disconnect this feature. Since I have a cable box connected to the tv, I use the cable remote anyway and therefore have no use for this feature. After disconnecting Anynet, the tv has not turned itself off again!! Finally, a solution that works!!! Hope this works for you too!!
We're glad that you're up and running Smiley Happy
