Screen mirror. I need help.
Re: Screen mirror. I need help.
Streaming from phone to tv. Using smart view.
After you did the factory reset, did you remove the television from the app on the phone and re-add it?
I dont have the app. I pull down the quick settings and scroll over a page and it says smart view. I have tried to download the app and it says i need to be on wifi to connect
Can you please explain in exact detail the steps you have used previously to connect the phones to the TV?
I would turn tv on. I would pull down the quick settings scroll a page over click smart view then it would find my tv and say it was connecting then it would be connect
Go to MENU>Network>Multimedia Device Manager and see if the devices are listed there.
My phone is not there.
We would recommend a software update on your device.
The tv or phone
[ Edited ]
We would recommend that the software is up to date on all devices.
