Smart TV won't connect to WiFi - Error Code: 102
SOLVED
Re: Smart TV won't connect to WiFi - Error Code: 102
Can I get you to send me your serial number via private message?   http://bit.ly/2kZXrit
Just checking in with you. Please get that information to us as soon as you can.
My TV is now refusing to do anything related to the internet. No YouTube, no Netflix, no Amazon, no nothing. It was working fine at 4:00 this morning. Now it's not.
The firmware is revision 1200. I have another TV which is working fine. I am going to be really annoyed if I have to reset my TV and reenter all my passwords. I have checked my network settings  Have tried wired and wireless and accessing an alternate network with no success  I've been using Google's dns servers for years, tried switching them around without success.
Can somebody assist me with this issue please?
@usergaN5J0S7cq: What's the model of your television?
Model UN60F6350
Software Version T-MST12AKUC-1200.0
I am having this issue as well. There is a connection from TV to router but won't connect to internet. Other devices work and have tried 3 internet routers and 2 wired connections. All fail. Also have done factory reset and DSN 8888. Please help!
Could you send me a private message with the serial number? http://bit.ly/2ihPL97
Same problem today with my 8000. Gets to my WiFi but not the internet and both Vizios work just fine. It worked last night but not tonight.
Model UN60F6300AF
Once again this was only a temporary fix and I’m right back at having the same problem. This so called “Smart TV” more often then not doesn’t work and it’s error after error. I’m so upset with the Samsung company and the persistent issues. Dealing with customer service is exhausting and every “solution” has either failed or temporarily resolved the issue and then we’re right back where we started. I have been dealing with this for over a year and a half.
Christinampond, the next step would be service. You can find a repair center using the following link:  http://www.samsung.com/us/support/service/location
