Smart TV won't connect to WiFi - Error Code: 102
SOLVED
Re: Smart TV won't connect to WiFi - Error Code: 102
@SamsungQue it does not. THe TV does not see any networks available.
Have you tried to factory reset and get the same result?
Having the same issues - the TV is connected to my network, but not the internet.  This has been happening for a couple months now.  Very frustrating!!!  ISP has sent two techinicians out and there is absolutely no problem with the internet...all other devices connect via wifi without issue.
By the number of posts on this and other message boards, it is glaringly evident there exists a real problem!  Samsung needs to find a solution to the flaw within their hardware...doing a factory reset or paying out of pocket for a "technician" is not a viable solution.
Please advise!!!
Why is there no real solution for this error!! Most expensive tv in my home and its the only one im having issues with!
@user8udgWVMaxM the solution is generally to update the software.
@SamsungGill wrote:
@user8udgWVMaxMthe solution is generally to update the software.
And how do I do that with no connection?
@user8udgWVMaxM It would be done via a USB flash drive.
@SamsungGill wrote:
@user8udgWVMaxMIt would be done via a USB flash drive.
Ok well I have no idea how to update via a usb.
@user8udgWVMaxM Please provide the full model code and current software version of the television by going to Settings>Support>Contact Samsung
@SamsungGill wrote:
@user8udgWVMaxMPlease provide the full model code and current software version of the television by going to Settings>Support>Contact Samsung
UN60H6203
T-NT14MAKUC-1200.2
