Two Samsung Smart TVs, two remotes
SOLVED
Re: Two Samsung Smart TVs, two remotes
I agree that not being able to run one new QLED TV with either of 2 remotes is frustrating. We each have a remote to eliminate certain inconveniences in trying to share a single unit. Please establish a firmware upgrade to enable multiple remotes to be paired with 1 TV if clients wish to use that option.
We will forward your suggestion accordingly.
Hi,
what is the solution please?
We just bought the frame as a second "tv" in the living room. When we turn on the TV ... the art mode stops and our painting becomes a TV!
Samsung I won't start with tape in 2019 on a brandnew smart remote.
Please provide a digital solution.
Thank you
