Bluetooth mouse input issues
(Topic created: 06-24-2022 01:52 PM)
userthCN6vyhSQ
Tablets
While editing some information. A message popped up concerning using my mouse as "input device". Apparently and inadvertently I chose "yes". No my mouse doesn't work. When I go to Bluetooth settings I now get the message "Unable  to connect to Bluetooth Input device while using it as a Bluetooth input device". It make no sense and I can fine no setting to fix this.
What do I do? I would hate to have to reset the Tablet to clear this.
Tablets
Long press the Bluetooth bubble in the drop down shade.
Find the mouse.
Tap the gear next to it.
Select Unpair at the bottom.
Re-pair your mouse.
bill-e
Samsung Care Ambassador
Tablets
If the above doesnt work, go to Settings->General Management-->Reset->Reset Network Connections
This will reet all your network including Bluetooth.
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy S21 Ultra 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch3 (VZW)
Who_Dis
Neutron Star
Tablets
what @bill-e said, you don't have to factory reset, just doing a Network reset will suffice.
