Power adapter charger
(Topic created: 12-27-2021 05:03 PM)
usermZx9F3fAa0
Tablets
I have a Galaxy Tab S 10.5 and I lost the power adapter.
What sort of adapter should I buy? I guess it should be 5v, but how many amps?
The manual doesn't say very much about this.
Thanks,
Jessica
Not applicable
Tablets
Hello! I will be happy to help you. The charger for the Tab S would need to be a minimum of 2 amps. The current Samsung replacement charger is available at the following link.   https://www.samsungparts.com/Products/Parts_and_Accessories/PID-EP-TA20JWEUSTA.aspx
1 Reply
Not applicable
Tablets
