userUR7V2zC9m2
Power configuration issue with Samsung Galaxy Book 12
JUMP TO SOLUTION
Hi.
I have some issues with running .NET application to preview video received from camera on Samsung Galaxy Book 12 (SM-w727nzkailo).  The application works well first 28 seconds and after that camera begins send frames with delay. The camera is connected to USB type c interface. I investigated the following behavior: in case tablet is connected to Samsung keyboard, the delayed frame reception begins exactly after the keyboard backlight is disappear. Moreover, if I touch the touchpad, the keyboard returns to be backlighted and frame reception is being normalized.
I have tested the application on some other much less powerful tablets then  Samsung Galaxy Book 12 and I have not seen  such behavior on them.
My question is which event causes keyboard backlight to disappear?
1 SOLUTION
Re: Power configuration issue with Samsung Galaxy Book 12
JUMP TO SOLUTION
Thanks for reaching out. This forum is for support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link: http://www.samsung.com/visitcountry
1 REPLY 1
JUMP TO SOLUTION
