Samsung Galaxy Tab S7 won't reboot after battery died NEED HELP
(Topic created: 11-07-2021 11:07 PM)
usertkZebgfs5v
Tablets
So my Samsung Galaxy Tab S7 battery died, so I plugged it in, and the charging symbol flashed on. I waited a couple of hours, and when I came back to turn it on, the Samsung logo flashed on, but it immediately flashed off. I unplugged the charger and plugged it back in. When I did so, the charging symbol flashed on then immediately flashed off. Afterward, the charging keeps flashing on then off, on then off, like a repeating cycle. When I tried a force reboot, the Samsung logo flashed on, but it immediately flashed off. When I hold down the lock button and the volume down the bottom, the Samsung logo flashes on then immediately flashes off, on then off, on then off, same as the charging logo. I have no idea what is going on. Is there a way to resolve this issue?
1 Reply
DENVERSKIER
Nebula
Tablets
Wondering if your battery charging cable is bad if so it may seem like charging but dead battery turn off
