Highlighted
Re: Smart Switch won't start, side-by-side configuration problem?
JUMP TO SOLUTION
Great, fixed my problem.
Highlighted
JUMP TO SOLUTION
awesome, installed Microsoft Visual C++ 2008 SP1 Redistributable Package (x86) on a 64bit machines win10 pro no problem, smart switch lit right up.
Highlighted
JUMP TO SOLUTION
We're glad that you're up and running Smiley Happy
Highlighted
JUMP TO SOLUTION
Hi hi
i installed the 2008 version as you suggested and it did help to solve the side by side configuration problem. However, another error came up. It prompted "the ordinal 12404 could not be located in the dynamic link library". Anyone knows what may the solution to ths be?
Thanks Lot!
Highlighted
JUMP TO SOLUTION
I have the same problem. Problem is not fixed. Error 120something came up, reinstalled the C++ pacage but no result. This side-to-side problem will remain :/
Edit: after installing it 1850 times it worked. I downloaded this one:
https://www.microsoft.com/en-gb/download/confirmation.aspx?id=5582
EVEN if I have 64bit computer
Highlighted
JUMP TO SOLUTION
Me too, the very same piece of software and it is not working Smiley Sad
Highlighted
JUMP TO SOLUTION
This worked for me finaly pfff
Windows 10 here on pc
Highlighted
JUMP TO SOLUTION
you are a bloody legend mate! finally a solution that works! thank you!!
Highlighted
JUMP TO SOLUTION
thank you sir very much
really i tried many times
thanks again
Highlighted
JUMP TO SOLUTION
Great.....
