userk8M3gmTDMP
Re: Smart Switch won't start, side-by-side configuration problem?
JUMP TO SOLUTION
many many many thanks sir..  it helped
userI6nOMJy34i
JUMP TO SOLUTION
Really i want to thank you too much for your effort and your smart advice that has been solving my problem.
user7kkjm4VCbD
JUMP TO SOLUTION
thank you for this link,it has solved my problem now i can install smart switsch without any problem
userSlwWw2HRcs
JUMP TO SOLUTION
Hi,
Thanks worked for me too (I`m on x64 still worked)
Weird that Windows 10 with all the uopdates needed this old software.
Many thanks.
David.
userMMq8PlSfYi
JUMP TO SOLUTION
Because Smart Switch need Microsoft old package to run.
userPgASOJLvON
JUMP TO SOLUTION
This worked for me also on windows 10 64bit.......
cheers..  :-)
userEm8BSdUxXf
JUMP TO SOLUTION
Hi, Thanks guys it worked and i was thinking it wont because i am running 64bit as i tried the 64bit version and that didnt work.
Thanks,
userNdXFu8l4Vf
JUMP TO SOLUTION
Thanks
user93yE3oRMVF
JUMP TO SOLUTION
Another piece of junk from Samsung, half done like Kies!
userx0mNyeJCkr
JUMP TO SOLUTION
worked fine for me. Thanks
