userxv0qDQhYlP
Re: Smart Switch won't start, side-by-side configuration problem?
JUMP TO SOLUTION
Where do i dowwnload this a5
useroO2n53wLIW
JUMP TO SOLUTION
This has helped. Thanks.
EdwardThe3rd
JUMP TO SOLUTION
I found if you copy that exact phrase and put it in Google one of the first results is a Microsoft webpage directing you to that exact file to download and install. Just a fun fact.
userTuvw0o6YZB
JUMP TO SOLUTION
This method did helped me to download successful. Thank you much
Shaukat
JUMP TO SOLUTION
Perfectly worked
user02zTfTQXd7
JUMP TO SOLUTION
OK, it help me
Umpahpah
JUMP TO SOLUTION
No! It is not working, on 2 PC's, one desktop and one laptop. On 1st, it is just a message stating "evaluating system conditions", and it get stucked, restart is needed. On second, while there is not "side by side" error, 1 get something "The ordinal 12404 could not be located... in the dynamic link library..."
If someone has a way around it would be wonderful to share! And I must say it is a shame from Samsung to distribute this kind of software. As I'm really not happy to spend 2 hours trying to install simple program!
userZwI7IwCMDG
JUMP TO SOLUTION
Didn't work
user7xHdZpCBTq
JUMP TO SOLUTION
this helped! thanks
userVxVtFXftPp
JUMP TO SOLUTION
Thank you, that resolved my problem
