userb7MdGN61CL
Re: Smart Switch won't start, side-by-side configuration problem?
JUMP TO SOLUTION
downloaded 2008 Microsoft Visual C++ Redistributable but when I redownloaded it, this message appeared
JUMP TO SOLUTION
I am having the same problem 12404 is not located in the dynamic link.
useriBRHTEkfWb
JUMP TO SOLUTION
for me the "12404 is not located" problem got solved when I installed also the Microsoft Visual C++ Redistributable *SP1* (x86) package: in fact the "plain" package is 1779 kB while the SP1 one is 4119 kB. I am running windows 10 enterprise 64bit
userDKRIim7d6n
JUMP TO SOLUTION
Perfect. Went to Microsoft, downloaded and installed the package. Problem solved :-)
Sowande
JUMP TO SOLUTION
This worked for me too. Why hasn't the problem been fixed? This will be one more major problem when the Note 8 comes and people are trying to set up Smart Switch and it doesn't work.
Tsk tsk.
NCorvelli
JUMP TO SOLUTION
Still did not help... It gives me an option to Run it but says "error ordinal link cannot find path"
userTM1Ip65ysh
JUMP TO SOLUTION
Thx a lot solved my problem
user3i61A7eloP
JUMP TO SOLUTION
After instatting its wont open, showing SCommon.dll is missing. Tryed uninstalling and restat several times. no luck
user3i61A7eloP
JUMP TO SOLUTION
Version is WIN10 x64
userDWT3enURLN
JUMP TO SOLUTION
That fixed it! Thanks!
