Re: Smart Switch won't start, side-by-side configuration problem?
JUMP TO SOLUTION
Thanks. Do you get any kind of error code or does the computer refuse to open the file? Does a file installer open? Is this an .exe file?
userFBCspNplBY
JUMP TO SOLUTION
Yes I do get an error code but forgot what it was it when I open the exe  file then it has an error what do I do?
Black Hole
JUMP TO SOLUTION
Hey, I would be happy to look into this for you. Please send us a private message to http://bit.ly/2CGMMUe with your phone number as well as the model number and the serial number of the unit.
userzby1A71CAM
JUMP TO SOLUTION
it doesnt work with me either installed microsoft visual c++ 2008
still get the same message side by side one
Black Hole
JUMP TO SOLUTION
I am sorry to hear this. I would be happy to look into it for you. Please send us a private message to http://bit.ly/2CGMMUe with your phone number as well as the model number and the serial number of the unit.
userT3tZ2rN0DH
JUMP TO SOLUTION
When I try to install the Microsoft Visual C++ 2008 SP1 Redistributable Package (x86)  it asks me if I want to repair or uninstall it?  I tried to both repiar it, and then uninstall and then re-install it, and neither worked.  Still receiving the side by side error.  Where to go from here....?
userT3tZ2rN0DH
JUMP TO SOLUTION
Actually just worked downloading smart switch from here
http://samsungsmartswitch.org/download.html
userZZUBfxWnK1
JUMP TO SOLUTION
this worked for me as well on windows 10
HITMAN
JUMP TO SOLUTION
Thank you so much I was having this same problem would not download but now I can thanks you you!thank you so much sir!
userjPtr20oYiB
JUMP TO SOLUTION
Yep that did it for me  Thanks much
