- Mute
โ03-19-2025 06:23 AM in
TipsI thought about a feature that allows us to control ringtone settings using the volume buttons and a double tap. This allows us to cycle through these three settings (sound, vibration, mute).
Something like this, in this order:
Double tap down: Sound > Vibrate > Mute
Double tap up: Mute > Vibrate > Sound
Using an alert to let us know the current sound setting.
For the "mute" setting, there can be a very brief vibration.
- Mute
โ03-19-2025 11:24 AM in
TipsHello,
Thank you for sharing your suggestion with us.
We truly appreciate your input and value your engagement in the One UI Beta community. Feedback like yours helps us better understand the experiences and preferences of our users.
Thank you again for contributing to the One UI journey.
Regards,
One UI Beta Team
