s24 Ultra Battery draining faster?
(Topic created: 12-07-2024 05:59 AM)
userjwYgoyU7fh
Cosmic Ray
Tips
Seems like the battery is draining faster after the install. Can this be investigated further?
Tips
The new u.i. will take some time to adjust to your usage and will start lasting longer, give it a few days. If it still persist, enter a bug report 🖖🏻
dalydose
Halo
Tips
This is more beta behavior than the often repeated "optimizing for your usage".
It's beta and it'll be fixed
Tips
This is new ui behavior, anytime a new ui is installed, battery drain is more significant as the system learns your usage patterns and adapts. There's nothing to be fixed, battery configuration is spot on according to benchmark testing. Most peoples battery drains faster during beta because they are on it more, checking out features and settings and playing around with what is new and such.
Bl8ck-c8t
Cosmic Ray
Tips
Give it some time. Mines isn't draining faster. Matter fact it feels like it improved the battery performance with the one ui 7
Youu
Honored Contributor
Tips
Have you tried clearing the cache
userjwYgoyU7fh
Cosmic Ray
Tips
Yes stills seems to be draining and getting hotter faster than before
Tips
My battery seems to be longer and less draining as well
USBetaModerator3
Beta Moderator
Tips
Hello,
Thank you for your feedback on battery consumption rate.
To assist us in resolving this issue, we kindly ask you to submit an error report through the Samsung Members app on your device:
1. Open Samsung Members.
2. Navigate to One UI Beta Program > Beta Feedback.
3. Attach any relevant screenshots (if possible).
4. Ensure "Send system log data" is checked, then submit the report.
Important: Please submit the report within 15 minutes of reproducing the issue for accurate log data collection.
We sincerely apologize for any inconvenience this may have caused and truly appreciate your contribution to improving the Beta experience.
Best regards,
One UI Beta Team
