user6vI9zxk1Si
Buzzing noise during agitation topload washer WA45H70000AW/A2
JUMP TO SOLUTION
The noise sounds almost like an electrical buzzer. Or maybe like gears stripping/slipping? Any ideas?
1 SOLUTION
Re: Buzzing noise during agitation topload washer WA45H70000AW/A2
JUMP TO SOLUTION
Could you send us a private message? http://bit.ly/2ihPL97
3 REPLIES 3
JUMP TO SOLUTION
How often are you hearing the noise?  Is it during the entire agitation process?
user6vI9zxk1Si
JUMP TO SOLUTION
Hello. Nearly all of it, in sync with the agitation, but probably not the entire time. Not a constant drone.
JUMP TO SOLUTION
