usertUvFeCznb5
Changing heating element on Samsung washer wf42h5000
JUMP TO SOLUTION
How do you access the heating element on the washer so I can attempt to remove small item in between the drums?
1 SOLUTION
Re: Changing heating element on Samsung washer wf42h5000
JUMP TO SOLUTION
We would suggest having a technician out to dismantle the washer.
1 REPLY 1
JUMP TO SOLUTION
