Cooling light on dryer
(Topic created: 03-19-2021 09:11 AM)
userrZKb3IHCHT
Washers and Dryers
Can you please tell me how to turn my the cooling light off on my dryer with model number DV40300EW.
SamsungAl
Washers and Dryers
The cooling light is supposed to be on when it hits that part of the cycle and there's no way to turn that off. If the cycle is complete though, unplug the dryer for about 5 minutes and that should turn the light off.
userplPjrtbZIc
Washers and Dryers
I am having the same issue with the cooling light not turning off. However,, like everyone else the clothes aren't drying as there were no heat. I took apart my dryer and found one (of many) thermostats on the heating element did not have continuity. After replacing it, I was able to dry my clothes again. However, the dang light is still constantly on. I may have to take it apart again to check the thermistor (which is located somewhere else, outside of the heating element).
user9qWWoXQKbW
Washers and Dryers
Does samsung seriously not answer stuff in a reasonable time. Im new here but I wish i hadnt signed up with an account because there are no answers here.
