Timetogo0711
Re: DV40J3000EW/A2 dryer Issue
JUMP TO SOLUTION
I'm having the same issue, but it happened 6 months after i bought it. 2 technicians came out and said its fixed. They didnt change anything.  I called the manufacturer and went through a couple steps.  Mainly turn off power to dryer for 2 minutes or more. Powered dryer back on and it started to work for like 20 minutes, then same issue.  I got another service call placed with samsung.  They better fix this dryer issue or start giving back my money or a totally new dryer.
userkiMfQhDk5a
JUMP TO SOLUTION
I to am having the same problem with my dryer we got it in September of 2017 and in October of 2018 it stopped heating I have to dry on the quick dry and it takes 2 cycles of 80 mins to get then dry and I had a repair man from the company I bought it from come look at it and replace something in once already I will never buy another washer or dryer form samsung...
JUMP TO SOLUTION
Hey, give this link a shot. It should help.
user4ngmwxLUOa
JUMP TO SOLUTION
I sure wish that I had read this before purchasing my set! Right now it is over-heating occasionally (bad belt/tensioner). Now it clunking and in-operable. I will try to repair it this evening, wish me luck. I guess my next problem will be the heating element in about 3 weeks. As said before in this string, "Expensive purchase for 1-year of reliability". Very,, very disappointed in Samsumg brand.
userE1QvgzIkBI
JUMP TO SOLUTION
This is absolutely a scam. How can it have this much complaints/break downs all within 2 years of acquiring the product. I took screenshot of all this and reached out to my lawyer. This is obviously a workmanship defect.
user0DDpjVAyrL
JUMP TO SOLUTION
I have a DV42H5200EW, and it has stopped heating probably six or seven times now. It's always the thermostats. I've taken to buying the parts in bulk so that I always have them on hand. No telling when it will fail again. Could be months, could be hours. I never bothered to contact Samsung because it didn't happen until my warranty was expired. Luckily I'm comfortable doing this sort of thing myself. I have a family that needs clean clothes, and I can't wait days for a repairman. I am disappointed in the quality of my Samsung dryer. I expected more, and in reading all of these other posts, it appears that I'm not alone. My experience and the experience of this forum in general lead me to conclude that I shouldn't buy any other Samsung appliances in the future. I had high expectations, but Samsung, you let me down.
userTnF3TwyRRv
JUMP TO SOLUTION
I have the same problem. Washer is garbage also but there is actually a recall on it
userpDzsJcLuy4
JUMP TO SOLUTION
Same issue here! Faulty heater coil. Its incredible how many people have the same part failing from 1-2 years, just outside of warranty!!!! Very clever of them... make it really cheap and flimsy but just enough to get by a year.  From what im reading they are losing a ton of customers because of this. I spoke to samsung on the phone too, had a tech come out and say all the same things. The tech knew what it was before he even opened it up, said its happening on all of these dryers. Samsungs response "Well your out of warranty so we cant cover it, theres nothing we can do".Really???? Nothing you can do about a part that costs $20 on amazon? How about taking care of the labor to have your faulty and cheap products fixed???? Dryers last 10+ years. Not 1-2 ???
There shouldve been a recall or a courtesy fix for the people who bought this dryer. Its a complete scam that this many people are having the same part break after 1 year.
userizbpXyntSh
dryer no heat
JUMP TO SOLUTION
ok modle # DV45H7000EW/A2 only a few years old i replaced the heater element ,thermostat,fuse,thermistor, and fuse. still no heat ? what am i missing? checked power 120 each and 240. what else is there? any help would be great or guess i go back to a different brand.
Re: dryer no heat
JUMP TO SOLUTION
Does this occur on all cycles? Is the exhaust vent clear of debris?
