Highlighted
Dryer Stopped Heating
JUMP TO SOLUTION
I have been trying to find out where I can get parts for my electric dryer. It comes on but no heat at all. The appliance repair shop in my area use to work on Samsung products but quit because the parts are so hard to find...can anyone give me some suggestions as where to find parts or who I could actually contact..
Highlighted
Dv3000 dryer not heating
JUMP TO SOLUTION
Does anyone have issues with their dryer not dryer and you having to run it 4 times max heat max time to get them dried? Is there a trick to not run it 4 times with the same clothes in it?
Highlighted
Re: Dv3000 dryer
JUMP TO SOLUTION
Here's a link that may help with your symptoms:
http://www.samsung.com/us/support/troubleshooting/TSG01000999/
Highlighted
Dryer not heating
JUMP TO SOLUTION
Dryer not heating. How long is warranty?  Model DV48H7400EW/A2
Highlighted
Re: Dryer
JUMP TO SOLUTION
Thank you for reaching out, our warranty is a limited 1-year warranty for parts and labor.
Highlighted
Dryer will not heat
JUMP TO SOLUTION
We replaced the heat element, thermostat, and thermal cut off switch. Worked for 1 day then no heat. This is a steam model, we bought OEM products. The new thermostat had a 50°  mark on it. This seems odd?
Highlighted
Dryer not heating & shutting off
JUMP TO SOLUTION
Hi, have a Samsung front load dryer. First, it would not stay on unless it was on "manual-time dry". Now we are having the issue that when we put it on time dry, it starts and goes for 1-2 minutes and then stops! It also does not seem to be getting hot at all.
Highlighted
Re: Dryer not heating & shutting off
JUMP TO SOLUTION
I'm sorry to hear that, can I have your full model number to better assist you?
Highlighted
Re: DV40J3000EW/A2 dryer Issue
JUMP TO SOLUTION
where can I Purchase Dryer Element
Highlighted
JUMP TO SOLUTION
If you would like to purchases any parts for your Samsung dryer you can purchase them at samsungparts.com
