DV45H7000 “Drying” Flashing and solid “Cooling” lights. Load not dry
(Topic created on: 2/7/21 9:56 AM)
userCZNK26yZ3R
Washers and Dryers
My DV45H7000 dryer is not drying. Had it on normal mode and not overloaded. The dial light was flashing and so was the drying light while the cooling light was solid. Opened it up and the clothes were pretty damp and not even warm. Is this a simple, inexpensive fix?
SamsungLarry
Washers and Dryers
Hey, give this link a shot: https://www.samsung.com/us/support/troubleshooting/TSG01000999/ If this does not help I recommend letting a service technician have a look. Send your full model code and serial number via private message to get started.
1 Reply
SamsungLarry
Washers and Dryers
