Dryer Cycles and Heat
(Topic created: 03-12-2023 12:49 PM)
reckless76
Washers and Dryers
I just got the Bespoke Dyer model DVE53BB8900DA3, and I'm confused. This thing has over 2 dozen different cycles to select from, but almost all of them use high or medium heat with no way to change that. All of my clothes, towels, and sheets say to tumble dry low. Am I just suppose to use the delicate or perm press cycles on everything? Why does this dryer have 5 different heat levels if it's only ever going to use setting 4 or 5?
Samsung_Moderator
Washers and Dryers
Hi there, Thanks so much for reaching out about this. I can certainly understand the frustration in having so many options, but not the options you want. I'd like to help you get the most out of the options you do have on this dryer. First, I'm providing this link to the user manual for this model.
https://downloadcenter.samsung.com/content/UM/202210/20221008062517897/DV8900B_SimpleUX_WEB_OID55762...
Pages 44 and 45 have detailed descriptions of all the different cycle options, as well as what types of items each cycle is best for. Page 54 has a cycle chart that shows which options are preset for each cycle, and which ones can be changed. You can also find other helpful charts on pages 53 and 55. Please let us know if this helps!
reckless76
Washers and Dryers
Thanks for the response. This confirms my observation, but doesn't answer my question.
All my shirts have 'Tumble Dry Low' in the instructions, but the Shirt cycle on this dryer uses medium heat. All my bedding says 'Tumble Dry Low', but the Bedding cycle uses high heat. Same with my towels. Their instructions all say 'Tumble Dry Low', but the towel cycle uses high heat.
Why is there such a disconnect between the fabric care instructions and the cycles meant for these fabrics?
