Dryer(DV56H9100GG/A2) control panel lights off but dryer works?
(Topic created on: 2/15/21 8:15 AM)
useryq99NeAwjV
Washers and Dryers
Hello,
Dryer model #:DV56H9100GG/A2,
I went to put close in dryer.  I turned it on and as soon as I went to touch the dial, the lights on the control panel went off.  I can still hear the selection noises when spinning the dial, but all lights are off on the display.  I am able to start the dryer and it heats fine, but I cant see selections.  I banged around gently on display to see if maybe something came loose slightly, but no sign of light.  Can anyone help fix this issue?  Thank you.
MrsThang128
Nebula
Washers and Dryers
You will need to replace the control board. This happened to mine. I was able to find a part in eBay for a reasonable price. It only about 10 minutes to disconnect and install the new part. Your part# is DC92-01647B. Watch a couple of YouTube videos for insight. And you are all set. Good luck.
useryq99NeAwjV
Washers and Dryers
Thank you for replying so quickly.
 I remember a couple of times, a while back, the lights would be on but the knob would not select anything or move the selection light.  It doesnt do that anymore by the way.  It happened a couple of times and I unplugged and plugged back in and it was fine.  Do you think this part you've listed has anything to do with this issue as well?
MrsThang128
Nebula
Washers and Dryers
Yes, this should correct that also. If that's all it was. This part will give you a new display.
