Highlighted
Dryer DVE50M7450/A3 won't start
JUMP TO SOLUTION
The lights turn on, but the drum won't turn.  It seems from the forum posts that this could be a heat sensor issue.  Do those burn out with use, or do they only trip or burn out because of an actual problem?  I inherited this dryer with the house so I don't know its age, but it's at least several years old.  And before I start taking this thing apart and ordering one, is there any other troubleshooting step I can take?
1 SOLUTION
Highlighted
Re: Dryer DVE50M7450/A3 won't start
JUMP TO SOLUTION
This type of issue will need to be addressed by having the unit serviced. Since it is out of warranty, you can use the following link to find a list of service centers near you that can do the repair: http://www.samsung.com/us/support/service/location
3 REPLIES 3
Highlighted
JUMP TO SOLUTION
I'm sorry to hear that, does this occur on all cycles? And have you tried to flip the breaker?
Highlighted
JUMP TO SOLUTION
Yes, I tried flipping the breaker. And it did not help. It doesn't seem to matter which cycle or setting we put it on. It beeps and the selector dial turns and lights up the different settings, but the motor simply does not start.
Highlighted
JUMP TO SOLUTION
