- Mute
07-16-2020 07:23 AM (Last edited 08-27-2020 07:41 AM by SamsungJam ) in
Washers and DryersBought a Samsung washer and dryer, had it installed on July 8 2020. I did 3 loads of laundry over a period of 3 days. On the fourth did a load of laundry and went to open the dryer door, the the inner glass just shattered. mind you I had no clothes in the dryer, just opened the door and glass went all over the place..
I am have problem with getting Costco.com to in contact with what their going to do about the situation.
Is this a common problem with the glass shattering and should just return the Dryer and buy some other brand. thanks
Solved! Go to Solution.
- Mute
01-22-2021 01:17 PM in
Washers and DryersYou can find parts for all Samsung products at samsungparts.com.
- Mute
02-28-2021 07:51 AM in
Washers and Dryers
II have noticed that the outer plastic door on my Samsung tumble dryer is cracked, it is in the utility room and has “not” been knocked. Upon reading through multiple posts I have reason to believe this is a common problem with this model, I bought the washing machine and tumble dryer, my machines are Both about 3 years old and have both been looked after.
- Mute
08-06-2021 06:53 PM in
Washers and DryersMy dryer is a little over 2 years old and the glass door shattered when my wife opened it this morning. It had not been used since the day before and has never had anything other then clothes in it. There is no way this should have happened. Seems like it has happened to several other people. Any recommendations on how to get this fixed? Thank You
- Mute
08-08-2021 06:55 AM in
Washers and DryersI can definitely understand how frustrating this may be. As we would like to gather additional information and look at this from a case by case basis please provide the full model code and the serial number of the device as well as your best contact phone number, name, and email.
Send a message on Facebook
Send Message on Twitter
Send Message to Moderator
- Mute
09-12-2021 10:53 PM in
Washers and Dryers
The inner glass door of our dryer shattered during a normal drying cycle. We have the DVE45R6100C/A3 model, and I’ve noticed other posts with this exact issue on this exact model, but it appears the issue was not covered by a warranty, even though this is clearly a manufacturing issue. I do not have the time nor the resources to purchase a new part and I’m wondering what the options are for me. We bought the washer and dryer last October 2020, so we are within a year of owning them when this happened.
- Mute
09-13-2021 04:35 AM in
Washers and Dryers- Mark as New
- Mute
09-13-2021 05:21 AM in
Washers and DryersI can definitely understand how frustrating this may be. Was anyone injured? I recommend letting a service technician have a look. As we would like to gather additional information and look at this from a case by case basis please provide the full model code and the serial number of the device as well as your best contact phone number, name, and email.
- Mute
09-12-2021 10:01 PM in
Washers and DryersHello,
had a small normal load today And noted that my inner glass door of my gas dryer shattered.
please advise
- Mute
09-12-2021 10:14 PM in
- Mute
09-13-2021 05:03 AM in
Washers and DryersI can definitely understand how frustrating this may be. I recommend letting a service technician have a look. As we would like to gather additional information and look at this from a case by case basis please provide the full model code and the serial number of the device as well as your best contact phone number, name, and email.
