Dryer making loud noise
(Topic created: 07-06-2021 09:45 PM)
userb1BVOpzjFb
Washers and Dryers
From what I've read on other boards, this is probably a drum roller problem.  But is there a way to find that out for certain without (a) taking several panels off the dryer or (b) calling in a service technician?  Does Smart Care help me do this and how do I even determine if my model has Smart Care installed?  Lastly, is it advisable for a fairly handy do-it-yourselfer to take apart the dryer and replace the rollers?
SamsungLou
Washers and Dryers
I will be happy to assist you. Please send the full model and serial numbers to this PM Link, and I will look in to this issue.
userdVPukoRKFp
Washers and Dryers
I am experiencing the same issue with m dryer. Can I get some support, please.
SamsungJam
Washers and Dryers
We would be more than happy to assist with this.  Could you provide the model of the dryer?  Is the noise constant or is it only when starting the dryer?  Is the drum still moving?
