Flex dryer not powering on
(Topic created on: 5/8/21 10:08 PM)
userafL42CQNv3
Washers and Dryers
The top dryer on my flex dryer model DVE55M9600V/A3 will not power on. What do I need to check or replace?  I have already unplugged it for a long time and plugged it back in with no change.   The bottom dryer works.
1 Reply
BoyAmIBonkers
Washers and Dryers
There's most likely a little sensor or switch somewhere on the door or hinge. If it's a gas dryer, make sure all connections are tight. Dryers have a few safety cutoffs to make sure they stay safe.
