Flex washer blowing fuse and locked door
(Topic created on: 1/2/21 3:45 PM)
userwhme4lEqoq
Washers and Dryers
I purchased this washer in May of 2019 and have been impressed with it most of the time.  The top washer has a balancing issue but it still works for the delicate loads I need.  Today, the bottom washer got part way through the cycle and dripped the circuit breaker.  We have tried many things including unplugging the washer.  The cycle resets and as soon as it gets going, it again trips the breaker.  I will drain through the emergency drain to see if we can get the door open but I've just had knee surgery so I will have to wait for help to do so.
Does anyone have suggestions for what could be causing the underlying problem?
1 Reply
SamsungAl
Washers and Dryers
This is something that is going to require service. You can use the following link to locate a service center near you: https://www.samsung.com/us/support/service/locations/
