Highlighted
Front Load Washer: Bang! and then smoke
JUMP TO SOLUTION
I have a front load washer model WF337AAR that made a loud bang this morning and then when I stopped it and opened the door, light smoke filled the laundry room. Drum still rotated when I started it again briefly.
Thoughts? Something I can fix myself?
1 SOLUTION
Highlighted
Honored Contributor
Re: Front Load Washer: Bang! and then smoke
JUMP TO SOLUTION
Oh no, that definitely doesn't sound good. Hope everything was ok, I'd like to have a member of our specialized team reach out to you. Mind shooting me a message with the below information? --> http://bit.ly/2igAXKH
Full Name:
Street address:
Email Address:
Best Contact Number:
Alternate Telephone NumberSmiley SadIf Available)
Place of Purchase:
Serial Number:
141 REPLIES 141
Highlighted
Honored Contributor
JUMP TO SOLUTION
Full Name:
Street address:
Email Address:
Place of Purchase:
Serial Number:
Highlighted
JUMP TO SOLUTION
Hi, I have your WF219ANW XAA washer, its about 10years old i think.   it just started to shake badly for my wife.  I put it in rinse and spin cycle to get 3-4 gallons of water in it, then I spun the water out and saw the shaking and what looked like wobbling of the drum.   I went online, clean debris filter which needed cleaning was recommended.   repeated the test then drum shook more violently and then I had smoke and shut it down.
ken johnson 919 696 3294
Highlighted
JUMP TO SOLUTION
Oh no! Could you send us a private message with the full model and serial number? http://bit.ly/2ihPL97
Highlighted
JUMP TO SOLUTION
Did anyone get resolution on this? I am having the same issue, started a couple of days ago.
Highlighted
Supernova
JUMP TO SOLUTION
Hey, I would be happy to look into this for you. Please send us a private message to http://bit.ly/2CGMMUe with your phone number as well as the model number and the serial number of the unit.
Highlighted
JUMP TO SOLUTION
I just had the same issue...my machine is 9 years old...is it just wearing out? I am totally freaked out...just filled my house with smoke last night...this is a major issue...what should I do?
Highlighted
JUMP TO SOLUTION
Mine just did the same thing about 15 minutes ago.  I wish someone would update this thread with the cause/solution.
Highlighted
Supernova
JUMP TO SOLUTION
For this, we do recommend having a service tech take a look at the unit.
Highlighted
Front Load Washer: smoke it really bad!!!
JUMP TO SOLUTION
Our front load RVT washer is smoking really bad.  What is the issue? Looks like lots of people are having the same issue! It’s only 9 years old. What should we do?
